Celica ST205 Gt Four
pipe work problem then
pepifebles
Re: Celica ST205 Gt Four
yes. Could I take oem map hose? Oem will be disconnected.astra vxr wrote:pipe work problem then
The fun starts now
Yes it will work ok
Your car the should work as factory one
pepifebles
Solved. New hose directly to intake manifold and run perfect.
In the other hand, when I received maps by mail to my mapper. How to write it in the ecu?
The fun starts now
You just need to use option Load project and then makes map permanent (F2 key).
However remote mapping is not the best solution
pepifebles
Its the only one solution possible for me.
Then, engine start or ignition on? Open project and F2
The fun starts now
i would have used the base map you have ( it dont look to bad ) and map from there even if you have a map sent to you it could be still off and still need mapping as no 2 engines are the same but each to there own
pepifebles
Yes, mapper have used base map and on this have change parameters. He sends me modified maps and I run it, log and tell him my impressions. Isnt easy but its possibleastra vxr wrote:i would have used the base map you have ( it dont look to bad ) and map from there even if you have a map sent to you it could be still off and still need mapping as no 2 engines are the same but each to there own
The fun starts now
pepifebles
My Engine originally runs watercooler. Watercooler Pump is controlled to oem ECU, and now I think that emu dont controller Good. Easy to see high IAT tenperature. There is Any option to run watercooler Pump with my new emu.
Regards
Regards
The fun starts now
If everything is right connected and you use the base map from Kuba for your engine, then the water pump is activated everxtime when the motor runs. Look at Parameter output 3 at the settings there is the output activated when rpm is higher than 600 rpm.
pepifebles
hi guys,
after three months of hard work, today I was able to dust off my car and continue configuration of my Emu Ecu . It is impossible to run well, I must have a problem with the map sensor because the idling its unstable, at iddle when I acceleratethe engine stop, just blowing 0.7 bar ( wastegaste pressure ), the mixture is very lean (1.25 to idle). This problem occur's with all maps (base map and other 2 maps).
Does anyone have any idea what happens ?
When I load base map, This error occurs, and when load my maps, this message it´s too much longer
The fun starts now
pepifebles
Ignore this message. It is just warning. Different software versions have different tables / parameters.
pepifebles
I reconnected the original ECU and the engine run fine, perfect. I connect the emu as I ever have all kinds of failures ( video above ) . Could this be mapping problem?
Regards
Regards
The fun starts now
Send the log file. We will see what is going on. Should work normally if everything is ok
pepifebles
Just press disc icon on the log window toolbar. The file will contain all channels so just press the icon.
pepifebles
Finally all runs ok but I dont get boost. I upload my log and my map
- Prueba Boost 01.emu
- Map
- (78.39KiB)Downloaded 68 times
- mapa prueba boost1 soplado.csv
- Log
- (20.34KiB)Downloaded 54 times
The fun starts now
