BMW M60B40
Kisielisodd
ECUMASTER TEAM
Re: BMW M60B40
Post by Kisielisodd » Wed Jul 01, 2015 11:37 am
vagman wrote:So, finally...
... DO respect what Jakub and his colleagues have done so far. It's time for prompt support though because some people just don't have much time and it's very disappointing to have to wait till the next weekend to try the adviced on the forum.
Did you try email at tech@ecumaster.com ?
pepifebles
Re: BMW M60B40
Post by pepifebles » Wed Jul 01, 2015 12:10 pm
no, I think if I do only ecumaster can to answer and that takes them time. However if I post here, perhaps a user could help and so do not bother Jakub. If ecumaster have Any problem with that, then ECUMASTER team tell me and I only ask to tech support email. I think that this is forum and its for this, between all users coment.
The fun starts now
SUKHOI
Re: BMW M60B40
Post by SUKHOI » Thu Jul 02, 2015 12:55 am
pepifebles wrote:I tried to set all I could. I've some doubts. I know that there are many but I appreciate that help me it what you can. For me its complicated.
My wiring are as follow. Do I need connect anything else?
Injectors, coils, crank sensor, TPS (M5 throttle body), wideband, ground, CLT, IAT, +5v.
Doubts:
Engine start cranking fuel 1 is neccesary to start engine?
Injector calibration. My injectors are Bosch 0280150792. How can know correct calibration?
Fuelling VE table is neccesary to start or can start engine set target AFR
Predefined coils? My coils reference is bmw 1 703 359. Bremi 11856 Bosch 0221504474. The emu options don’t match with mines.
Coil dwell time configure? I have no idea what it this.
Main relay its neccesary connect to emu?
VSS and gearbox is neccesary set to start the engine?
Thank you very much in advance.
Thats good, so far, what about the power and GND? a well GND will solve you the noise issues and give you max protection for your device and makes it easy to tune and so on
Doubts:
it is needed but you can start with default values and change later for better tune, if you noticed that the engine is not starting you may need to adjust it a little, based on reading your spark plug (too much fuel that floods the engine or to much low fuel that is not making the engine to start, but in general I noticed that this engine starts even when there is too much fuel, so I think this will not worry you that much, but always read you spark plug after three or four cranks, and make sure to use new spark plugs to make it easy for you
Thats 245cc injectors as they are high impedance, you can select any of the predefined Bosch in the injector wizard, or just simply leave it as default, and you can get back to that later when you get stable idle.
Just set the lambda table as a start then you can tune the VE and Lambda later, you can start with 1 lambda or 0.95 at cursing and idle area and then refine the tune when it starts
set them at 2.8ms at your battery voltage (14V) as a start, and from that number shape your table later, I usually stress these coils more.
Not at all, I always do my wiring to start the EMu and other devices at ignition ON from key switch, a external relay that powers the fused EMU,Injectors,Coils, and and activate the fuel pump and fan relay, but its up to you how to do your wiring, I like to use dedicated relays and fuses for max safty.
No.
Re: BMW M60B40
Post by RHD » Thu Jul 02, 2015 10:41 am
wow this thread is a bit of a disgrace! thanks to the rude hijack! I think admin should edit or delete some or most of this thread.
To the Original Poster you can sometimes learn quite a lot by looking at other peoples maps, even for different engines there are plenty all over this forum so maybe download a few have a flick through some of the tables ans settings and see if you can learn from what you see.
also are you using the latest software/firmware? https://dl.dropboxusercontent.com/u/286 ... 33exp1.exe
every feature in the software has a help file (little blue ? ) this will explain what it does and how to set it up, and of course study the user manual there is most of the information you need right there
pepifebles
Re: BMW M60B40
Post by pepifebles » Fri Jul 10, 2015 9:19 pm
Today have Tried start my Engine and havent luck. Do not injection. Injectors and coils can take ground to chassis or necessary to emu ground?
The fun starts now
pepifebles
Re: BMW M60B40
Post by pepifebles » Fri Jul 10, 2015 9:46 pm
I attached my log while swith key on.
V8 log.emulog
Log
(11.23KiB)Downloaded 82 times
The fun starts now
Re: BMW M60B40
Post by Jadzwin » Fri Jul 10, 2015 9:49 pm
Injectors and coils are switched to ground so it must be connected to switched +12V at one side and to INJ / IGN outputs
pepifebles
Re: BMW M60B40
Post by pepifebles » Fri Jul 10, 2015 10:01 pm
Ok. Please see my log. I change trigger edge from falling to rising and now have injection but dont start.
V8 Rising casi arranca.emulog
Log
(6.82KiB)Downloaded 78 times
The fun starts now
Welshman
Re: BMW M60B40
Post by Welshman » Fri Jul 10, 2015 10:02 pm
on mine the coils must be grounded too
pepifebles
Re: BMW M60B40
Post by pepifebles » Fri Jul 10, 2015 10:08 pm
I attached my "base map". You know that it make for me (anything knowledge) but I get spark and injection ;). Could you tell me if you see anything bad configured to start the engine. The car havent knock sensor, no iddle valve, no cam sensor connected.
Mesa Mapa base By Febles.emu
Base map
(77.85KiB)Downloaded 99 times
The fun starts now
pepifebles
Re: BMW M60B40
Post by pepifebles » Fri Jul 10, 2015 10:10 pm
Welshman what its your engine? I use stck BMW ground wire
The fun starts now
Welshman
Re: BMW M60B40
Post by Welshman » Fri Jul 10, 2015 10:25 pm
mine not a bmw . but a 3sgte but with coils with built in amps .
4 wire coils have 12v in , ground , signal and reference ( can ignor ref wire )
but i dont know what the bmw has just just ignore me . im tired been up since 3am :)
SUKHOI
Re: BMW M60B40
Post by SUKHOI » Sat Jul 11, 2015 12:59 am
Sure you need to ground the coils, your coils have 3 pins 12v+/Ground/Signal
From the log file it seems that your MAP sensor is not connected, connect it to vacuum source.
Set the cranking ignition angle into 10 if not 15 yours is 2 that's too low for cranking, that what I noticed so far, did you check if your having enough fuel? (By reading spark plugs) if they are completely dry try to add more fuel on cranking enrichment, beware not to flood the engine or you will kill the spark plugs, I always like to use fresh new spark plugs at the first start :) but after making sure that am not going to flood the engine for sure.
pepifebles
Re: BMW M60B40
Post by pepifebles » Sat Jul 11, 2015 9:58 am
Actually my coils grounded to chassis but I asked if its necessary grounded to emu or with chassis its ok. I checked that there is spark then its ok.
Crank ignition angle changed to 10. ;)
I havent enough fuel. I need more. How do it? Cranking fuel its set to 3, prime pulse 1, fuel target 14,7.....
Thanks.
The fun starts now
pepifebles
Re: BMW M60B40
Post by pepifebles » Sat Jul 11, 2015 10:58 am
Somebody can make base map for me? I pay it. My tuner have too knowledge in remap stock ECU but this is different. He needs a good base map. If somebody can make it I can pay him.
The fun starts now
pepifebles
Re: BMW M60B40
Post by pepifebles » Sat Jul 11, 2015 1:53 pm
started :o amazing. Never thought that Start.
The fun starts now
SUKHOI
Re: BMW M60B40
Post by SUKHOI » Sat Jul 11, 2015 9:52 pm
Here you started it, so no need to pay ;)
as I told you increase the cranking enrichment, and it's ok to put something less than 14.7 as a start, if you noticed that the car needs like 3 or 4 cranking to start that definitely means you are low on fuel, prime pulse 1 at cranking is too little, at idle you should see between 1 to 3 , and more on cranking.
Ground the coils on chassis not on the same place for EMU, its better to reduce noise
pepifebles
Re: BMW M60B40
Post by pepifebles » Sat Jul 11, 2015 10:47 pm
Start perfect and iddle perfect but too rich At iddle, about 10 or less :( and when push throttle there is misfire. However today Feel very happy jeje somebody like me get start the Engine making base map, my own simplify wiring, harness etc
Only need fix any little things and later its work to my tuner.
Thanks for your help.
The fun starts now
SUKHOI
Re: BMW M60B40
Post by SUKHOI » Sat Jul 11, 2015 10:51 pm
;) Good job, with more practice it will be easier and faster
SUKHOI
Re: BMW M60B40
Post by SUKHOI » Mon Jul 13, 2015 12:24 am
Correction: Prime pulse used to add fuel before cranking, I meant to say you should see around 2 or 3 pulse width at idle, not prime pulse, it should be Zero if you are using gasoline fuel, with other fuels like e80 and methanol it is required to add some fuel before cranking so here where prime pulse is used :)
