Need Wiring for Toyota 1NZ-FE (VIOS)
DET3 technical support
Baroto
Post by Baroto » Sun Jan 17, 2016 6:51 pm
Hi...
Any one can help me about wiring diagram to install DET3 for 1nzfe engine.
As attach is ECU wiring diagram.
ECS1.pdf
1NZFE ECU Diagram
(76.39KiB)Downloaded 156 times
CKP Signal
regards,
Baroto
Baroto
Re: Need Wiring for Toyota 1NZ-FE (VIOS)
Post by Baroto » Tue Aug 30, 2016 6:57 am
Dear admin
How can i unlock rev limiter?
Kisielisodd
ECUMASTER TEAM
Post by Kisielisodd » Tue Aug 30, 2016 10:12 am
You are not able to do it in piggyback mode. Rev limiter is controlled by stock ECU.
2 solutions
1 - Stock ECU Remap
2 - FIT mode for DET3
Baroto
Post by Baroto » Thu Jun 01, 2017 9:35 pm
Kisielisodd wrote:You are not able to do it in piggyback mode. Rev limiter is controlled by stock ECU.
2 solutions
1 - Stock ECU Remap
For option 2. FIT Mode.
If rev limit cut off by ignition from main ecu. How can i manipulate?
runedk
Post by runedk » Sun Jun 04, 2017 8:53 pm
Not possible to change ignition rev limiter. Only fuelcut can be changed in FIT mode
Baroto
Post by Baroto » Tue Jun 13, 2017 9:54 pm
runedk wrote:Not possible to change ignition rev limiter. Only fuelcut can be changed in FIT mode
Can you give me schematic for toyota 1NZ-FE in FIT Mode.
If I want to install Individual throttle body, how about to convert MAF to MAP internal 400kpa.
