So I'm thinking about ditching my gauge cluster completely. I plan to install a windows tablet and just configure the gauges to use as the cluster.
My speedo is cable driven though, so I was wondering about purchasing a GPS speedo module
http://www.autometer.com/universal-gps- ... odule.html
Do you guys think I can wire this directly to the EMU for the speed sensor? I was looking through the settings and don't believe it's possible.
From the manual it says "The Auto Meter GPS Speedo Interface outputs a 12v square wave that is compatible with every electronic speedometer we tested".
There's only three wires; power, ground, and signal. So if we can install it to one of our analog inputs, and have it read the speed. Would be nice to have a GPS speedo anyway.
GPS Speedo Question
Re: GPS Speedo Question
connect to power and ground and the signal wire directly to the VSS vehicle speed input and it should work perfectly!
