Hi
Is it possible with staged injection to add the second injector to the primary injector.
The instructions indicate that as secondary injector percentage increases primary injection percentage decreases. This is fine for most applications with small primary and larger secondary injectors.
In our application we have two 840cc injectors per cylinder running methanol, to give an acceptable idle we would like to use just primary injector then adding secondary in as load increases to give us a maximum injection capacity of 1680cc per cylinder.
Is this possible.
thanks
Chris
Staged Injection function
Re: Staged Injection function
Hello. I would like to learn more about the implementation of the phased injection function. I have the sr20vet rwd engine under control of ecu master emu. implemented two racks first with small injectors 260cc, second 720cc.
Please recommend parameters for proper operation. and do I need to specify in the phasing (injector phase) belonging to the ignition?
chris72 wrote: ↑Thu Jan 19, 2017 7:24 pmHi
Is this possible.
thanks
Chris
Just write 50% from 100kpa.
