lambda wide band
hello , I have no information rcal in pin 2/6 on lambda wide band, but between pin 1/5 jai an ohm information. How to connect you lambda probe. The red / yellow / black wire or connect them. Thank you
Re: lambda wide band
all the information is on the laminated pin connection card that came with your EMU, or in the user manual
Hello, thank you for replying but I have a problem with I have no information and graph I am always a 1. What bosch reference used for wide band
not information afr . what is problem ?
- Sans nom 1.odt
- (132.06KiB)Downloaded 88 times
Here is a log of startup
- logChannels.xml
- (27.41KiB)Downloaded 71 times
