Toyota mr2 3sge trigger
Botasjr
Post by Botasjr » Wed Mar 08, 2017 9:00 pm
hi
after some information colected on this topic viewtopic.php?f=19&t=10906&p=20522&hilit=3sge#p20522
i made my onw plug and play adapter, for now everithing seams to be fine, tps, clt, iat, etc,
but, on the trigger its a little diferent compared with other base map from an St205 that is on this forum,
with my configuration the spark jumps at 10º btdc when ckranking, i didnt conect the injectors yet,
someone can share other base maps for this engine, and analyse my scope and base map?
regards
3sge sync.zip
(9.85KiB)Downloaded 67 times
scope_201738_1848 10 degre crank.zip
(385Bytes)Downloaded 62 times
Botasjr
Re: Toyota mr2 3sge trigger
Post by Botasjr » Thu Mar 09, 2017 8:03 pm
job done
thanks to ecumaster info
my punout its a little diferent
NE - primary
G2 - Camsync
D8 - yes D8 - sensor ground.
start okk.emu
(101.72KiB)Downloaded 67 times
log ok.emulog
(196.88KiB)Downloaded 59 times
scope ok.emuscp
(329Bytes)Downloaded 59 times
Botasjr
Post by Botasjr » Mon Mar 20, 2017 11:39 am
There is a video of the final result
everithing works fine
for now
320 Hp at 0.8 Bar
https://www.youtube.com/watch?v=Ldv5DPZHy0I
