1jz running rich
ryanaxberg
1jz running rich
Post by ryanaxberg » Tue Mar 14, 2017 4:45 am
I have a 1jzgte running a emu and I got it running but it is really rich and just not running right. I put siemens deka 80lb injectors in it and it has better flowing intake and 3 inch straight pipe. Other than that it is stock. I loaded a stock 1jz tune on it and changed the injector size up to 875cc and I used the injector wizard for the injector calibration. I checked and it is getting spark at every cylinder and the fuel pressure is set to a base pressure of 40 psi. It shows that the target afr is 14.7 at idle but it is at like 10.0 afr. I have messed with the the idle reference table and that doesn't seem to change it very much. If anyone has any suggestions of what it might be I would appreciate it. Thanks
1jz base map.emu
(102.31KiB)Downloaded 130 times
Re: 1jz running rich
Post by PSI-Motor » Tue Mar 14, 2017 5:06 am
Go get it tuned!
ryanaxberg
Post by ryanaxberg » Tue Mar 14, 2017 5:10 am
thanks for the help
fataznwithcake
Post by fataznwithcake » Wed Mar 15, 2017 4:22 am
I'm having the same issue. I'm using sard 800cc injectors. I even rewired the injectors and converted to sequential injection instead of batch fire (I have a non-vvti 1jz). I'm running the emu in advanced lambda with a 1.0 target at and around idle. I can crank the ve fuel table all the way down and still idle a 10.0 afr (.68 lambda). I even tried adjusting injector latency since that was the issue I had when I was running these injectors with the stock ecu and Emanage Ultimate. Now I'm stumped. If you figure it out please let me know! I'll do the same.
fataznwithcake
Post by fataznwithcake » Wed Mar 15, 2017 5:30 am
Strangely enough, mine decided to idle just now. Attached are my config file and a short data log from when it wouldn't idle.
last emu export.emu
(102.3KiB)Downloaded 127 times
start stall.emulog
(21.14KiB)Downloaded 111 times
ryanaxberg
Post by ryanaxberg » Thu Mar 16, 2017 1:59 am
Yeah, I don't know man. I got it to run a little better by increasing the injector size, but it doesn't seem like that is the right way to do it. I think I will probably take it to a tuner by me and hopefully he can figure it out. I like doing stuff myself, but I don't really know what else to do at this point. I will let you know if I get it sorted out.
tommyboyblitz
Post by tommyboyblitz » Thu Mar 16, 2017 1:48 pm
Injector size is not important. I have standard 370cc standard injectors in my 1jz gte vvti, my tuner had to set them to 500cc to get the car to run right.
I am now changing to 550cc injectors and my tuner said to set to around 700cc just to takr it to be tuned again as it wont be perfect.
So just changing the injector size in the setting wont solve anything, it will have to be tuned.
fataznwithcake
Post by fataznwithcake » Fri Mar 17, 2017 6:44 pm
Mine is running fine now. Injectors were wired for sequential fire. The idle correction (duty cycle) that was set in the base map I got was way off. I had to change the values to between 50-60 and i adjusted the set screw on the TB. Lower DC raises idle. Higher DC lowers idle. I set the injector dead time for my SARD 800cc hi-Z injectors to (i think) manufacturer setting that i found on google. Base fuel pressure is set to 43.5psi. Cold starts are still a little rough until the afterstart time period set in the idle parameters expires.
Once it ran close to perfect i enabled PID and ignition control for idle. It idles between 14.3 and 15.3 AFR now.
ryanaxberg
Post by ryanaxberg » Sat Mar 18, 2017 9:03 am
cool, I'm glad to hear it. Are you talking about the idle reference table is what you made all of them between 50 to 60?
Post by RHD » Sun Mar 19, 2017 12:53 pm
..shaking head with fingers on forehead....
im glad to see you guys jumping in and learning but you really should do the following before you go any further!
update to the latest test version software (see announcements section of the forum) then update the firmware in your ecu (go online with the ecu, Files/ Update firmware) convert your AFR table to Lambda, fill out your charge temp table and change to ADVANCED LAMBDA fueling (fueling/ General) set your correct injector size in the settings! I see one of you is using the advanced fueling but you still need to fill out your charge temp table.
THEN make it run at the correct AFR/ Lambda by adjusting the VE table and watching your lambda gauge on the TUNE DISPLAY
if you do any tuning with basic fueling it is not as good and your whole VE table will need doing again if you ever want to update to the much better advanced fueling.
ryanaxberg
Post by ryanaxberg » Sun Mar 19, 2017 8:07 pm
thanks, I will give it a try. I tuned a evo that I had but this is a bit more involved.
jssteinke
Post by jssteinke » Mon Apr 03, 2017 11:54 pm
ryanaxberg wrote:thanks, I will give it a try. I tuned a evo that I had but this is a bit more involved.
Can you update on your findings, I'm also working on my 1J with siemens deka 80lb's and running super rich with the 1J ID1000 tune I found on the facebook group with injector size lowered to 875, dead times adjusted properly.
Going to try converting to advanced fueling once the weather gets nicer.
ryanaxberg
Post by ryanaxberg » Thu Apr 06, 2017 12:02 am
It is working better but I still have to do a bit of work to it. The throttle responds is pretty bad also. I also disabled the idle valve because I want to delete it at some point.
most recent.emulog
(254.98KiB)Downloaded 123 times
1jz base map.emu
(102.32KiB)Downloaded 139 times
tommyboyblitz
Post by tommyboyblitz » Mon Apr 17, 2017 11:23 pm
your target map looks a little odd and flat....
