base map Mitsubishi Galant 4g64
wencel
Post by wencel » Fri Mar 17, 2017 12:39 pm
Can someone share base map for Mitsubishi 4g64 2002 ? There are problems with the parameters Primary trigger and Secondary trigger
Now we have
20170314_2101.emulog
(456.83KiB)Downloaded 83 times
roquete
Re: base map Mitsubishi Galant 4g64
Post by roquete » Fri Mar 17, 2017 4:57 pm
wencel
Post by wencel » Mon Mar 20, 2017 3:40 pm
Now as in the maps from the evo, but the car does not work. Evo, two camshafts, 4g64 one camshafts. How to choose the right second trigger?
roquete
Post by roquete » Mon Mar 20, 2017 5:29 pm
4g64 may have SOHC or DOHC, which sensor do you have?
CAS module on the camshaft or crank and cam sensors separated?
wencel
Post by wencel » Mon Mar 20, 2017 5:33 pm
roquete wrote:4g64 may have SOHC or DOHC, which sensor do you have?
I have SOHC
two sensors, crank and cam sensors separated
roquete
Post by roquete » Mon Mar 20, 2017 5:59 pm
sorry now i see you have already wired them up.
Just use the scope function of the software and post it here.
wencel
Post by wencel » Mon Mar 20, 2017 6:03 pm
roquete wrote:sorry now i see you have already wired them up.
Here I saved
scope_201714_1633.emuscp
(47Bytes)Downloaded 93 times
roquete
Post by roquete » Mon Mar 20, 2017 6:08 pm
why are you using cam#2?
post your project file, and how many thooth does the primary trigger have?
wencel
Post by wencel » Tue Mar 21, 2017 10:15 am
roquete wrote:why are you using cam#2?
Very strange, once showed it, I saved it.
I will attach another file later.
galant-4g64-T-560ccзапустилась (1).emu
(77.95KiB)Downloaded 113 times
roquete
Post by roquete » Tue Mar 21, 2017 11:05 pm
you have the same settings i have for a evo3 with cas on camshaft like this:
these are my settings:
if your trigger on crankshaft is only 2 teeth like this settings are ok maybie you need to enable pullup
