V Twin down on power
chris72
Post by chris72 » Fri Apr 21, 2017 7:54 pm
Hi
We have recently converted a suzuki TL1000 turbo to EMU and have an issue during tuning. The bike revs well in neutral and 1st gear after that it seems slow to rev and is down on power.
WEe have more dyno time booked for next month but could someone look at the log and the project in case we have missed anything obvious as the owner insists on running it on the track before the dyno.
Bike is running on 100% ethanol.
thanks
20170421_1855.emulog
last run log
(175.42KiB)Downloaded 156 times
final 21-04.emu
Current project
(101.93KiB)Downloaded 132 times
Re: V Twin down on power
Post by RHD » Sat Apr 22, 2017 9:30 am
55 degrees of spark advance on a boosted engine!!!.... thats extremely high!! im surprised it hasnt damaged a piston
also its very rich you should be aiming for lambda 0.95 at least idling and light throttle, maybe 0.85 at 100 Kpa and graduating to around 0.75 at maybe 1 bar of boost and over
chris72
Post by chris72 » Sat Apr 22, 2017 11:32 am
I have wondered about the timing, it is accurate while cranking and at idle however if we run less timing the engine makes even less power ? is it possible that the ignition timing is not correct at higher rpm ( 16-2 trigger)
As the bike runs on ethanol it should be relativley safe from detonation while the boost is still low i will make some changes to the fuel map as you recommend
many thanks
Chris
Post by RHD » Sun Apr 23, 2017 7:01 am
easy check: lock the timing to 0 then rev the engine up with a timing light, see if you still have 0 timing, pay to make a mark for each cylinder and check them both!
chris72
Post by chris72 » Mon Apr 24, 2017 10:26 pm
i will get that checked, as soon as the engine is repaired it would appear that on this engine using ignition retard for launch control results in damage to the cam buckets. Any suggestions for a smoother launch control stratergy.
Chris
