converting 1jz to sequential injection
ryanaxberg
Post by ryanaxberg » Mon May 29, 2017 5:54 am
Hi, I have a jzz30 that I am trying to convert from batch to sequential injection. I watched the video that you guys have on youtube about it an I thought that I did the same thing but I am getting a constant ground on the number 5 injector, which I now have the pin set as G14, that was origionally set as the main relay output. It showed that the main relay output was originally G14 but there wasn't a pin in that spot. I switched the main relay output to G5 but I don't know what the pin would go to since there wasn't anything that it was going to before. Do you know what I should do with the main relay output or why there would still be a constant ground on the G14 pin that I have for the injector 5 now? Thanks
ryanaxberg
Re: converting 1jz to sequential injection
Post by ryanaxberg » Tue Jul 04, 2017 1:37 am
sdffffffffffffffffffffffffffffffffffffffffff
1jz base map.emu
(102.39KiB)Downloaded 139 times
ryanaxberg
Post by ryanaxberg » Wed Aug 29, 2018 8:46 am
htttttttt
20180513_1308_27.emu
(102.26KiB)Downloaded 112 times
