Hi
Can someone point me in the right direction for setting FPRD failsafe, i have an idle fuel pressure of 3.44 Bar at 100 KPA manifold pressure this increases on a 1 to 1 ratio with boost so at 228 KPA i have 4.69 Bar fuel pressure (max boost is 300 KPA)
what values should i use to ensure i maintain the correct fuel pressure ratio.
thanks chris
Fuel pressur delta settings
Re: Fuel pressur delta settings
Log your FPRD and you will see yourself. It should not change much across load/rpm.
i didnt know that was logged, i will have a look and base settings from that.
