Hi
How do you control boost through the ecumaster
I have a mac valve connected to my external wastegate top port and intake pipe
Do you need to get a guage for boost levels or can this be monitored through the ecu
Boost control
- jt-performance
- Contact:
Re: Boost control
You need to go to the software and you will find the boost section
Open some screens and hit F1
Everything is explained.
Also you need to connect the bottom port.
First go without a solenoid or with a solenoid not connected and be sure everything else is fine.
Then hook up the solenoid and slowly add some duty cycle to the boost map
Ecumaster the Netherlands
