M50B30 fuel problem
Support for EMU BLACK device
plamen83
M50B30 fuel problem
Post by plamen83 » Fri Jun 23, 2017 6:15 pm
Hello i have a problem with my e46 330 m50 vanos engine.
On steady 4500 5000 or 5500 with no load the afr go below 10.
There no fuel corrections and changes in map,ve or tps and fuel ms go from 1.5ms to 2.5 or 3ms.
Here a log and my basemap file.
Any ideas?
FINALPETAK.emub
(120.38KiB)Downloaded 76 times
FRIDAY.emublog
(23.2KiB)Downloaded 60 times
Re: M50B30 fuel problem
Post by Karel » Fri Jun 23, 2017 11:13 pm
Well,
there is no M50B30 engine on the this Planet....
What is your engine really ? M54B30 double vanos ?
If you have Vanos engine and your VVT is not set, you will end with very strange looking engine.
Do you call it tuned engine ? Its terrible what i see.
Or do you have some "Clone" engine and it is turbocharged or what ?
plamen83
Post by plamen83 » Sat Jun 24, 2017 9:46 am
Sorry its m50b25 3ltr stroker
M52 crank pulley.
The engine is 8.5 cr with holset hx35
The car run on boost fine without a problem.
This happened only in this rpm range and between 4500-5500and 70-100Kpa.
With vanos on and off its made it.
Here the map
niki 2.emub
(120.33KiB)Downloaded 93 times
Post by Karel » Sat Jun 24, 2017 1:36 pm
Your car is not tuned well. Just look into the VE and IGN maps and you will know. Only issue is bad tune, nothing else.
