Hi all,
I'm working on a 04 Mazdaspeed Miata, and am getting False Secondary Trigger.
The Cam gear has 4 identical teeth, and the crank has a strange tooth setup, set up the same way as a 99-00 miata.
So the cam gear has four even spaced teeth, and the crank has a four tooth setup.
False Secondary Trigger Error
Re: False Secondary Trigger Error
Its only your "FAULT"
You just need to switch the edge fro rising to falling (or oposite)
Then look into the scope and set the secondary trigger to N+1 ........... finish
So I scoped it with your settings and still have issues.
Is there a way for me to attach a scope?
