Bluetooth Adapter on EMU Black
I'm wiring in a serial port for the Bluetooth adapter (not DL-1). The BT adapter needs 3.3V, and the only output on the black is 5v. Is this "safe" for the BT module, or do I need to lower voltage to 3.3V?
Re: Bluetooth Adapter on EMU Black
Use 10ohm resistor. Check how to connect yours
bt module with arduino (atmega328) and do the same.
