m50b25tu problem
selfdestroyer
my engine have problem with idle, on 870cc siemens deka injectors I have PW 1.5ms, I change to 630cc siemens deka injectors, but injectors pw at idle same 1.5ms at 14.7 AFR. Fuel pressure 3 bar.
- 630cc1.emu
- (102.35KiB)Downloaded 113 times
selfdestroyer
Re: m50b25tu problem
very small pw, injector can't working stable, bad idle, always after I depress throttle engine stopping.
may be engine running on semi-sequential mode?
I run 2500cc injectors all the time and i don`t have any problems. First of all go in to your fuelcut parameters, and raise your fuelcut from 1500rpm to 2000rpm and 1250rpm to 1800rpm. And overrun decay rate from 100% to 20%. Raise your ignition on 650rpm and 450rpm range.
play with your injector dead times
