Running a starter with the PMU
All information about power management unit
driftkids
Post by driftkids » Sun Nov 19, 2017 8:21 pm
Is it possible to join two outputs on the PMU so it can run the starter signal that requires abt 30 Amps ?
jgm
Re: Running a starter with the PMU
Post by jgm » Mon Nov 20, 2017 4:56 pm
Yes.
In PMU-16 there are two types of outputs: 25Amps and 15Amps. (10 x 25Amps and 6 x 15Amps)
You can join outputs if they are of the same type. For example: 25Amps+25Amps or 15Amps+15Amps.
Up to 3 outputs can be joined together.
See example, how to set it up in PMU Client:
