2jz vvti setup
DET3 technical support
Kontraburna
2jz vvti setup
Post by Kontraburna » Thu Nov 30, 2017 5:16 pm
Hello, I am trying to get a det3 up and running on a is300 with a gt35r aristo swap using the is300 ecu. I cant seem to get the ignition to synchronize ... does anyone have the wiring diagrams and ignition settings for a is300. something to get me going? I have it wired per the 1jz instructions with #5 out going to the is300 ecu and number 9 coming from the crank sensor. thank you... any help is appreciated .. thanks again
