2jzgte vvti base map
farristrey
Post by farristrey » Fri Dec 15, 2017 7:00 pm
Rather than building a MAP from scratch, Im trying to reach out to the community to see if anyone is running this on the standard EMU. Im running smart coil and ID1050s. Im searching for a base map just to get me started. Im running full sequential with a tweakd wiring harness. Any map out there to let me build of would be terrific. My email is farristrey@gmail.com If someone has one and can send me it I would be in your debt!
paryoto.semesta
Re: 2jzgte vvti base map
Post by paryoto.semesta » Sat Dec 16, 2017 4:05 am
Base_Map.emu
(102.33KiB)Downloaded 233 times
farristrey
Post by farristrey » Sun Dec 17, 2017 4:14 pm
Thank you that got me on the right track. One thing I'm looking at and not understanding is the "Ignition events" which are 1 5 3 6 2 4 compared to "Injectors Phase" which are the same 1 5 3 6 2 4. So on the second ignition event, the "Injector 2 phase" is firing on ignition event 5. So wouldn't this mean injector number 2 fires as coil number 5 is sparking? Thanks for any clarity, and I'm looking in the manual right now also. I thought maybe that injectors phase should be 1 2 3 4 5 6. Im sure that isn't right but I cant understand why. Thank you all
farristrey
Post by farristrey » Sun Dec 17, 2017 6:04 pm
I found it in the manual. It is correct the way it is.
