first question is I see you can combine 2 outputs for a bigger amp output, setting it up in the software is straight forward but what I cant find is how you wire that up to your output?
for example I want to wire up a fan, do I only need to connect the fan to 1 of the 2 outputs I combined on the pmu or do i need to wire it into both the output pins?
second question is, can I wire multiple items upto 1 output on the pmu?
for example could I wire up my haldex controller & digital dash off 1 output? i was presuming this would be ok and would work fine but just wanted to make sure?
I'm sure ill have more questions
thanks
