hello i am having a problem with emu black and drive by wire.. i have a 2jzgte vvti with a 22030-46160 throttle body .. i have it wires just as the manual says.
the throttle motor connected to h-bridge 1 channel (positive a ) (negative b).
pedal position sensor connected to tps in for the main and analog 6 for the secondary .
tps connected to analog 1 and analog 4
and i have the clutch wired to a 12v relay
i calibrated my sensors but i still cant seem to get it right..
i opened up the throttle by hand all the way and closed it a couple of times and made a log to record the sensor values but something still seems to be off..
it seems like the h-bridge is not sending power to open and close the throttle.
do i have it wired wrong? do i have it setup wrong in the software? am i missing something?
https://drive.google.com/file/d/11DQqos ... sp=sharing
https://drive.google.com/file/d/1ut550f ... sp=sharing
