Ignition stage and timing angle issue.
Zazzn
Post by Zazzn » Mon Feb 26, 2018 9:52 am
Hello all,
First, let me state that I don' have many hours into the EMU but I'm learning fast.
Problem
The engine will crank, start but will idle with a miss. Trying to sync the engine I notice that it's way out and the timing looks retarded from TDC by at least 15 - 20 degrees.
Timing fixed at 10 trying to sync.
Timing light sits between coil 1 and spark plug wire to plug 1.
Adjusting the ignition angle from 60 to 45 brings the timing close to TDC but the car has a very hard time idling and sputters or dies and misses it seems more.
Engine Specs / Setup
Stock Aristo 2jz-GTE (mapsensor based ecu)
EMU PNP harness
EMUB
External WB on input 6
Below you will find my sync scope, map and logs.
scope_2018225_1826.emubscp.txt
(520Bytes)Downloaded 91 times
20180225_1826.emublog
(308.33KiB)Downloaded 72 times
87Turbo4.emub
(125.54KiB)Downloaded 80 times
