I saw the thread for the AEM failsafe calibration, but was wondering if the file will work for the X-line as well. My AFR readings between the wideband and the DET3 is off by about 1.7-2 points with the wideband reading lower.
Has anyone else had issues like this with an AEM UEGO?
DET3 + AEM UEGO X-Line calibration
Re: DET3 + AEM UEGO X-Line calibration
Your wideband grounded to same ground as Det3 ?
For X-series 30-0300, try this one instead.
Definitions spec:
volt = [0.50 0.75 1.00 1.25 1.50 1.75 2.00 2.25 2.50 2.75 3.00 3.25 3.50 3.75 4.00 4.25 4.50];
afr = [8.50 9.09 9.69 10.28 10.88 11.47 12.06 12.66 13.25 13.84 14.44 15.03 15.63 16.22 16.81 17.41 18.00];
coef0: 7.3116
coef1: 2.3761
coef2: -0.00016512
coef3: 0
coef4: 0
coef5: 0
Interval: [8.4996 18.0008]
Mean AFR Error: 0.0023578
- wideBandO2SensorAEMUego_X-series_30-0300.txt
- Change ext to .def
- (412Bytes)Downloaded 152 times
Just saw that this gauge has the exact same spec as AEM failsafe...
@NgoFcukinWay, can you double-check the model number on your gauge?
NgoFcukinWay
30-0300 Is the correct part number.
NgoFcukinWay
DET3 AEM UEGO X Line calibration
What is the make/model of your monitor and the calibration tool you are using ?
