r32 gtr skyline start up help
r32gtr
Post by r32gtr » Wed Feb 17, 2016 8:42 pm
Does anyone have a working startup map for a r32 rb26 nissan skyline gtr? I have a copy of the rb25 startup map but it doesnt look like any of the outputs are mapped. Is it typical to have change all of these? This is my first ecumaster ecu so I don't really know what to expect, but on other stand alones with start maps all of the outputs are ready to go usually.
specs:
1990 nissan shyline gtr
emu plug and play kit w bluetooth module
stock injectors
stock coils
intercooler upgrade
roquete
Re: r32 gtr skyline start up help
Post by roquete » Wed Feb 17, 2016 9:22 pm
You will always have to set the outputs and aux inputs to a startup map.
Unlike other ecu's you can use in example unused injector or ignition output to anything so all depends on how you wire it.
Startup maps are to make it easier on trigger and basic settings and fuel / ignition maps.
r32gtr
Post by r32gtr » Wed Feb 17, 2016 9:40 pm
I havent changed any wiring from the pnp yet but I am going to add wiring for the fuel pressure sensor at some point, and since my factory boost control solenoid is missing, I am going to add wiring for that. For now however I am just using the pnp. Being that the pnp wiring adapter is a circuit board, how exactly am I supposed to know which outputs are wired where?
