The car the ecu is going into is a MK3 supra with a 7mgte engine in it. I am in the process of building my own engine harness, and bought the EMU wiring kit. For the most part it is pretty straight forward, but there are some questions I am running into, and I rather build the harness once and do it right rather than have to unloom everything after its together and restart.
The question on top of my head right now is can I use both high and low impedance injectors with the ecu its self and no resistor box? I know I was reading around a little bit in the manual, and I believe I could use a pull up resistor to be able to use low impedance injectors. Is that right? My tuner is recommending I go with High impedance injectors, so in that case I can just plug in the injectors an go is that correct?
I will try to update this thread with my wiring schematics I made along with the questions I have already ran by Zach along with the answers he has given me, and any further questions since I know I will have many. I may throw up some pictures too if you are lucky too.
