Several disconnection after update
killerbee
Post by killerbee » Sun Oct 19, 2014 6:06 pm
Hi
I do not have problem with logging since I update to 1.061 exp 1 , now the laptop disconect after some time and I must unplug USB and plug it again , I think that it is connected with quick saves ( can they be turned off ) . It makes such problems on car power adapter and on 220v volt adapter in my garage . I check in log by the time of disconect there are no problems in all parameters
Re: Several disconnection after update
Post by Jadzwin » Mon Oct 20, 2014 2:52 pm
Did you try without external powering of your laptop (using laptop battery only) ?
killerbee
Post by killerbee » Mon Oct 20, 2014 3:46 pm
No
It is old laptop , can this 10 to 20 hrz sampling be the problem ...
Post by PSI-Motor » Mon Oct 20, 2014 10:05 pm
Im not having any trouble. Try changing your usb cable
killerbee
Post by killerbee » Wed Oct 22, 2014 8:25 pm
Today make 20 min log with other laptop on battery , have one disconnect right after hard 100% wot acceleration , unplug usb cable and plug it again then no problem ( without closing emu soft ) . Will see if there will be more problems tommorow
