Does anyone have a method for creating a cam sensor on the BW M20 engine? In stock trim BMW uses a coil around the #6 spark plug wire to detect cam location. Can this sensor be made to work?
Thanks for the help.
BMW M20 Cam sensor
Re: BMW M20 Cam sensor
Here's your answer, works like a charm on my engine.
https://www.ebay.com/itm/BMW-M20-M30-bi ... 3621795090
Very clever and simple. Now I have to ask you about which coils and plugs you used. Do you have any pictures of the mounting? Thanks
'87 BMW E30 track car
M20B25 block 86mm 3.123ccm
M54B30 crank 89,6mm
M54B30 rods 135mm
JE pistons 86mm 12.5:1
Ported 885 head
Schrick 288
NUKE camgear
RHD itb’s
RHD flywheel 3,7
Hartge manifold
Ecu Master ECU
Bosch 3x2 wasted spark
E34 M5 3,6 injectors
Adjustable Malpassi fuel pressure regulator
Untitled
M54B30 crank 89,6mm
M54B30 rods 135mm
Ported 885 head
Schrick 288
NUKE camgear
RHD itb’s
RHD flywheel 3,7
Hartge manifold
Ecu Master ECU
UntitledRe: BMW M20 Cam sensor
The file is attached here Nicky761.
But you can't use the ign table or fuel table when our engines are different. But some settings should do.
- PhillipHamilton Rullefelt 264hk 327nm - 2.emu
- EMU file
- (103.33KiB)Downloaded 105 times
