ANDROID DASH - VERSION 2.1.0 - Available in Google Play
Kisielisodd
ECUMASTER ANDROID DASH already available in Google Play!
https://play.google.com/store/apps/deta ... ev.emudash
ECUMASTER DASHBOARD connects to ECUMASTER EMU engine management system via BT module, showing real time data of critical engine parameters. All data also could be stored to log file for further analysis.
Please check http://www.ecumaster.com for more information.
The followings parameters could be displayed:
- RPM
- MAP
- TPS
- IAT
- AFR
- CLT
- LAMBDA
- BATTERY VOLTAGE
- IGNITION ANGLE
- INJECTORS PW
- SEC. INJECTORS PW
- INJECTORS DC
- EGT #1 and #2
- KNOCK LEVEL
- DWELL TIME
- CURRENT GEAR
- BARO PRESSURE
- ANALOG #1,#2,#3,#4
- ECU TEMPERATURE
- OIL PRESSURE
- OIL TEMPERATURE
- FUEL PRESSURE
- ETHANOL CONTENT
- FUEL TEMPERATURE
- VEHICLE SPEED
- FUEL PRESSURE DELTA
- FUEL LEVEL
- TABLES SET
- CHECK ENGINE CODE
- RPM
- MAP
- TPS
- IAT
- AFR
- CLT
- LAMBDA
- BATTERY VOLTAGE
- IGNITION ANGLE
- INJECTORS PW
- SEC. INJECTORS PW
- INJECTORS DC
- EGT #1 and #2
- KNOCK LEVEL
- DWELL TIME
- CURRENT GEAR
- BARO PRESSURE
- ECU TEMPERATURE
- OIL PRESSURE
- OIL TEMPERATURE
- FUEL PRESSURE
- ETHANOL CONTENT
- FUEL TEMPERATURE
- VEHICLE SPEED
- FUEL LEVEL
- TABLES SET
- CHECK ENGINE CODE
Re: ANDROID DASH - VERSION 2.1.0 - Available in Google Play
Looks good and I'd like to make use of this but I'm a bit of a retard when it comes to phones and tablets etc
I have a Motorola with Android software and I see 10" tablets on Ebay for about £50 with Android Is it the same software for both phone and tablet ?
Can data logging be done to the phone or tablet ?
I wan't to use wide display with arduino board. Can it be modified for that display, it's my personal project
BigMac wrote:Looks good and I'd like to make use of this but I'm a bit of a retard when it comes to phones and tablets etc
yes android is android tablet or phone its the same
Was looking at this on Ebay with Bluetooth 4.0
http://www.ebay.co.uk/itm/10-INCH-QUAD- ... 2a4a52f9fc
I'm still having issues with MAP display in imperjal units along with fuel pressure delta not working.
pepifebles
My android phone connect perfectly but dont read any parameters. All show 0.
The fun starts now
and did you configured your emu output ?pepifebles wrote:My android phone connect perfectly but dont read any parameters. All show 0.
- emudata.JPG (24.63KiB)Viewed 46106 times
pepifebles
Ups
each day learn new things
Can I connect android app by usb (faster than BT)?
The fun starts now
Looks cool!!!
Flemming Rosborg
RiiS DRiFT
Follow on Facebook! facebook.com/riisdrift
RiiS DRiFT
pepifebles wrote:Upseach day learn new things
Only BT connection is possible
It is on our to do list and will be fixed/ added in next software updateAlec wrote:I'm still having issues with MAP display in imperjal units along with fuel pressure delta not working.
Got it working eventually
I'm not sure where it is better to post feature request for Android app - here or under common topic "Bugs and Feature requests". In order not to mix into common pool with firmware and PC app I'm posting here.
Two very much needed features for the Android Dash:
* Auto Connect [Enable/Disable] - when Enabled automatically connect to predefined paired device and automatically reconnect after loss of connection;
* Auto Start Logging [Enable/Disable] - when Enabled automatically start recording log file after establishing connection.
Many thanks
Many thanks
+1 on thatezukas wrote:I'm not sure where it is better to post feature request for Android app - here or under common topic "Bugs and Feature requests". In order not to mix into common pool with firmware and PC app I'm posting here.
Many thanks
I habe problems with logging.
I made 4 Loge with the app but Windows client cannot read them.
Two of the logs Werke at least 2 Minuten long.
But client only shows 10 seconds or so....
- EMULog_20000104_093954.log
- (123.79KiB)Downloaded 403 times
- EMULog_20000104_092632.log
- (10.94KiB)Downloaded 416 times
- EMULog_20000104_090843.log
- (108.26KiB)Downloaded 331 times
And the fourth...
- EMULog_20000104_094549.log
- (33.6KiB)Downloaded 333 times
I tried two more logs....but client does not open them...no errors, or messages...just no graph...
Stupid question: Do I have to be connected to emu???
Yes you do, first pair your phone/tablet with bt to "emubt" device, use code 1234.
Then open the app and choose "emubt", dont forget to choose ecumaster serial protocol in EMU.
Feature request:
Option to choose the logs folder location, and/or upload or share to a dropbox or cloud account.
Great app keep up the good work, tanks.
