Trigger settings for Nissan ca18det s13?
Grey
Post by Grey » Thu Dec 04, 2014 8:35 pm
I am looking for the trigger settings on a Nissan ca18det s13. What trigger does it have, some speak about CAS and some about a 24+1?
Is there anyone that has used the factory harness with an adapter and got it to work?
Thanks,
Joakim
Re: Trigger settings for Nissan ca18det s13?
Post by PSI-Motor » Thu Dec 04, 2014 9:29 pm
Im running adapter loom in my nissan Ca18det.
It is cas settings. Send me an e mail Joakim.
Post by RHD » Wed Feb 11, 2015 1:53 pm
I will also need one of these for a CA18 soon, does anyone have a base settings/tune to share?
thank you
Kisielisodd
ECUMASTER TEAM
Post by Kisielisodd » Thu Feb 12, 2015 10:00 am
proven working configuration
Post by RHD » Mon Feb 16, 2015 4:07 pm
That is perfect, thank you
yiipi
Post by yiipi » Sun Mar 08, 2015 1:05 am
Can speed meter work with emu?
Post by Jadzwin » Mon Mar 09, 2015 1:37 pm
In your car the signal from gearbox (VR sensor) goes to dashboard and then to ECU.
So your speed should work normally with EMU, and you should provide speed signal from your dashboard to EMU
eugen_troll
Post by eugen_troll » Thu Mar 12, 2015 7:31 pm
Has anyone base ignition timing map for ca18det?
Stock or allready tuned.
Big thx
Post by PSI-Motor » Thu Mar 12, 2015 8:53 pm
eugen_troll wrote:Has anyone base ignition timing map for ca18det?
Big thx
E85 or regular pumpgas?
eugen_troll
Post by eugen_troll » Thu Mar 12, 2015 9:17 pm
Big thx
Regular pumpgas.
yiipi
Post by yiipi » Tue Mar 17, 2015 10:13 am
Ok. Tnx. Is there any base map for this engine?
Kisielisodd
ECUMASTER TEAM
Post by Kisielisodd » Tue Mar 17, 2015 10:30 am
Try this one, it's from our coworker car early configuration
CA18DET.emu
(72.82KiB)Downloaded 153 times
yiipi
Post by yiipi » Wed Mar 18, 2015 10:38 am
what would be a suitable IAT for this setup? I assume built in map is ok...
ktsirigotakis
Post by ktsirigotakis » Wed Mar 18, 2015 3:19 pm
on the back of the intake there is a one way valve for the breather i have removed the one way valve and put iat sensor there, i did it because i have an oil catch can its nice and looks like factory location
yiipi
Post by yiipi » Wed Mar 18, 2015 10:31 pm
witch one you've put there?
ktsirigotakis
Post by ktsirigotakis » Fri Mar 20, 2015 5:34 pm
ecu master iat
first start right now!!!!!!!!!!!!1 few problems trying to find solution.
s13 doesn't have fuel pump relay????? i cant find it
ktsirigotakis
Post by ktsirigotakis » Sat Mar 21, 2015 3:12 pm
i have some problems with my clt cant find the values to calibrate it dose some have them?
Post by PSI-Motor » Sat Mar 21, 2015 6:34 pm
Pin 18 in Nissans harness is fuelpump
ktsirigotakis
Post by ktsirigotakis » Tue Mar 24, 2015 6:33 pm
PSI-Motor wrote:Pin 18 in Nissans harness is fuelpump
Thanks psi but i have remove the old wiring due to terible contition. Any way i have fount the problem my friend had marked worng the wire :oops:
