can anyone forward me wiring examples of rb/sr wiring for emu, also trigger wheel set up
and tps for twin plug would be nice aswell
rb20/25 cas sensor wiring/ set up
Re: rb20/25 cas sensor wiring/ set up
tps sorted, anyone can help with cas sensor??
Hi!
Here is a wiring table for RB25DET and the map that allows to start the engine (RB25)
- mapa_rb25det.emu
- RB25 base map
- (45.46KiB)Downloaded 363 times
- RB25DET.pdf
- Connection table
- (72.31KiB)Downloaded 365 times
Hi is it possible to run a Rb25 det neo6 from an R34GTT with this basemap too? Or are there any problems because of the varible camshaft?
Outclass-Performance
- Contact:
Yes
rb25det neo starting with this map
http://www.outclass-performance.com/
Team Outclass
Performance
Team Outclass
Performance
louie588279
Jadzwin wrote:Hi!
I used this base map, for Rb25det s1 but didn't fire up, Need help on getting to start with base map, it starts up fine with the stcock ecu and safc just not with the ecu standalone with base map, help please
post up a log of some cranking and the actual map from the ecu
