Hello
Is there a way to improve the delta TPS reading.
The sample rate is already at 120 msec.
My rate at normal driving is alway's at 1-8 !!
Even sudden throttle i reach 20-30.
TPS filter is very very low. (mode1 and 15 or something )
The scale is to small to get a good acc erichment calibration on normal driving i think.
Maybe set the hor table axis at 50% or something ?
Delta TPS
Re: Delta TPS
Hi
There is no TPS filter
It is quite strange because 120ms interval is relatively long..
Re: Delta TPS
Sorry must be confused with MAP filter
Re: Delta TPS
Here isthe log from this afternoon.
Giving good throttle i get spikess if about 28 max.
But normal traffic is much lower.
Releasing throttle gives higher spikes.
Found one of 63.
I assume this is normal because you release the throttle faster.
Found one of 63.
- 20150119_1704.emulog
- (802KiB)Downloaded 88 times
Re: Delta TPS
Hi Jadzwin
Had the time to take a look at my log yet ?
Grts
Patrick
Grts
Patrick
Re: Delta TPS
Can you send me your project. It is unusal especially for integrator constant equal to 120...
