IAT sensor wiring
DET3 technical support
kamikaz33
IAT sensor wiring
Post by kamikaz33 » Wed Jan 21, 2015 5:23 pm
Hello, since the car doesnt have a IAT sensor, how would the wiring be done to the DET3?
Ground -> sensor -> Analog#4 IN(pin16) ???
Or should the +5V Output be used with a Resistor trough the sensor to the Analgo in beeing the resistor value the one used in RX on calibration Menu?
+5V out(pin12) -> XXK Resistor -> Sensor -> Analog #4 IN(pin16) ??
BTW it is a Vauxhall Calibra Turbo (C20LET) Threaded 2 pin IAT(is this the GM IAT type in default sensor Types)??.
Thank you!
kamikaz33
Re: IAT sensor wiring
Post by kamikaz33 » Wed Jan 21, 2015 6:33 pm
ok, nevermind, that is on the FIT Manual and i guess the +5V out is good for this.
Is it just me or it looks like everytime we take a look at the manual there allways seems to be something new on it...
in case someone comes with the same doubt...
ktsirigotakis
Post by ktsirigotakis » Thu Jan 22, 2015 2:10 pm
5v from det3 to one pin of clt and other pin to analog 4
kamikaz33
Post by kamikaz33 » Thu Jan 22, 2015 2:46 pm
Yes, thats how i have done, but with a 2k resistor on it which was i had in handy, and seems to be working ok! :)
ill make my own Knock detector/analyser now and i should be fine to start tuning it properly as soon as the wideband arrives!
thanks!
ktsirigotakis
Post by ktsirigotakis » Thu Jan 22, 2015 5:09 pm
don't blow up the engine good lack 8-) :D
ihiryu
Post by ihiryu » Thu Sep 17, 2015 10:35 pm
First off, sorry for bumping such an old thread.
My question is with the IAT, I'll be using a GM unit. There's also a preloaded scale from ECUMasters built into the DET3. If I hook up the IAT, will I still have to run a resistor?
