Hi to all
I have notice that the tps rate is jumping all the time looks like there is a noise or its very sensitive how can i solve my problem.
the AFR is jumping also and i believe its its from the tps rate that goes up and down.
i have two logs one with tps enrichment and one with map enrichment, analog in is my wideband innovate
its a peugeot 106 16v jp4s engine
how i will upload the log??? wont let me upload it only if i zip it
TPS rate is jumping FIT mode
- ktsirigotakis
- 106 16v logs.rar
- (111.79KiB)Downloaded 99 times
Re: TPS rate is jumping FIT mode
I have the same jumping tps rate thing.
Did you solve it?
Did you solve it?
