punto gt with emu
kostas
punto gt with emu
Post by kostas » Tue Feb 24, 2015 8:14 am
Hi my friends, i' m new at programming...my engine firing order is 1342 with wasted spark directly to emu (1212, g8g16g8g16 pins), the injectors are full sequential, are also 1342 ??
my trigger type is bosch 60-2 with vr, and ignition angle is 114BTDC, First trigger tooth is 19 (114/6) ??
i have fuel and spark but don't start
i have a lot o of questions!!!
thanks a lot.
Re: punto gt with emu
Post by PSI-Motor » Tue Feb 24, 2015 8:44 am
Try tooth 10 and angle 54. Use a timing light.
kostas
Post by kostas » Wed Feb 25, 2015 12:13 pm
ok thanks now it's start.
Post by PSI-Motor » Wed Feb 25, 2015 1:34 pm
kostas wrote:ok thanks now it's start.
Great. Keep us posted :)
kostas
Post by kostas » Mon Mar 02, 2015 2:05 pm
hi my friends, i have two qestions, 1) emu connect only with wideband knock? i have the oem knock (punto gt knock) and from 0,7 to 5 value (min tps to max tps) with pressure or not, i give only the frequency value from my Car piston diameter (7.2khz) what it's need to work? , i'm new at sport....
2) how can i measure trigger angle with ignition light, because at flywheel where the numbers it can't be (turbo take place), at the other side at belts i have only one point, i must find numbers to write?
