Setting up Boost control
PBU
Post by PBU » Tue Feb 24, 2015 8:05 pm
Hi
How should i set up the boost control to work only as a limiter ?
No boost curve or anything.
Just limit pressure at 220 Pa for example.
My control valve at 0% DC => all the presure to the turbo waste valve.
100% => all the pressure is flown to airfilter box.
Grts
Patrick
Re: Setting up Boost control
Post by Jadzwin » Tue Feb 24, 2015 8:50 pm
In your case the easies way is to use PWM table.
On X asis there is a load. So if the load is higher than required set 100%DC and interpolation does the rest.
PBU
Post by PBU » Wed Feb 25, 2015 9:36 am
Thx
I get a warning that i use the same output as boost control aux1 ( of course )
Wiring another output for the boost valve is a very big job !!
The tekst is in red now.
I disabled the "normal" boostcontrol, so is this a problem is use the same ouptut twice ?
Patrick
Post by Jadzwin » Wed Feb 25, 2015 1:55 pm
You cannot use one output to two or more strategies.
Just select output to none for boost control.
