Dash and Logger compatability and protocols
Post by RHD » Wed Feb 25, 2015 11:38 am
Hi can you put up a sticky post with a list of all the CAN protocols and dash/ data loggers that are compatable?
This is something i get asked on a regular basis
Aim sport dash data logger is the latest question, will this one work??
thanks
Re: Dash and Logger compatability and protocols
Post by Jadzwin » Wed Feb 25, 2015 1:56 pm
Hi!
You can use: AIM (serial) or any Dash that supports: Motec M800 SET1, HALTECH E8 E11v2, RaceTechnology (direct connection), PECTEL SQ6 or any dashboard / dataloger that allows defining user frames.
Tgood
Post by Tgood » Fri Feb 19, 2016 7:05 am
When using the aim MXL strada which ecu are you supposed to use in the aim settings? Ecu master is not on its list
Wuniek
Post by Wuniek » Fri Feb 19, 2016 11:46 am
You must change output of external port in EMU software (lots of info can be found in help on each function window in EMU):
Tgood wrote:When using the aim MXL strada which ecu are you supposed to use in the aim settings? Ecu master is not on its list
Tgood
Post by Tgood » Fri Feb 19, 2016 6:25 pm
I've read thru it. Have it all wired in but in the aim settings for ecu selection. Ecu master is not on the list. I guess I will try a few and see which one works
