Turbo Control
peter1002
Turbo Control
Post by peter1002 » Mon Apr 20, 2015 2:40 pm
Hello
have a problem with my turbo pressure
I'm not over 0.4 bar
my motor is a Z20LET
20150323_1723.emulog
(1.31MiB)Downloaded 112 times
20.04.2015.emu
(77.75KiB)Downloaded 131 times
astra vxr
Re: Turbo Control
Post by astra vxr » Mon Apr 20, 2015 10:12 pm
what boost control valve are you useing ?
also whats with the spark map ?
peter1002
Re: Turbo Control
Post by peter1002 » Mon Apr 20, 2015 11:13 pm
I have the original Turbo with valve control.
Ignition map I have not yet been set.
Are you a base map for me?
Thank you Peter
Re: Turbo Control
Post by PSI-Motor » Mon Apr 20, 2015 11:37 pm
Something is really really really wrong, dont drive that car.
astra vxr
Re: Turbo Control
Post by astra vxr » Mon Apr 20, 2015 11:44 pm
i dont have a map as of yet :(
why are you trying to put boost through the engine when its not mapped off boost ?
looking at the data log you dont even see wot
even on crap fuel you can run a little bit more timing than 10-12 deg even on boost its so far retarded its unreal i havent had a good look at everything as of yet as im useing a tablet to read this on but i will have a look when i got home on a bigger screen :)
Re: Turbo Control
Post by PSI-Motor » Mon Apr 20, 2015 11:54 pm
Ignition map.
astra vxr
Re: Turbo Control
Post by astra vxr » Mon Apr 20, 2015 11:56 pm
just seen something
primary trigger settings dont look right
first tooth trigger ( there isnt a number )
trigger angle ( 117 deg ) thats not right
1st tooth trigger is 9
trigger angle is 60
Re: Turbo Control
Post by PSI-Motor » Mon Apr 20, 2015 11:57 pm
You can start with that ignition, maby take out a couple of degres to be safe.
astra vxr
Re: Turbo Control
Post by astra vxr » Mon Apr 20, 2015 11:57 pm
PSI-Motor wrote:Ignition map.
is that from the file posted ?? if so i must be doing something wrong as ive loaded the same one and i have differnt settings ???
Re: Turbo Control
Post by PSI-Motor » Mon Apr 20, 2015 11:59 pm
astra vxr wrote:just seen something
trigger angle is 60
60-2. 117 degres is almost the same as tooth 9 and 60 degres, tooth 9 + 60 degres is 114.
Re: Turbo Control
No i did a ignition map for him
astra vxr
Re: Turbo Control
Post by astra vxr » Tue Apr 21, 2015 12:01 am
PSI-Motor wrote:No i did a ignition map for him
ha ha though i had loaded up the wrong file :)
no that will be fine at that prob could add a bit more to it but it will be well safe for that engine more worring is the trigger setup ?
Re: Turbo Control
Post by PSI-Motor » Tue Apr 21, 2015 12:06 am
He he :)
The trigger setup is almost correct, depending on ignitionsystem delay it should be 114-117 degres. But it is a VR sensor standard if my memory serves me correct :)
You can choose to do teeth count as you said or just use the angle as he did. I would like to see a scope log and se if the polarity of the sensors are correct.
astra vxr
Re: Turbo Control
Post by astra vxr » Tue Apr 21, 2015 12:09 am
trigger angle is 60
dumb mode kicked in yes correct i think its lack of sleep for me there are some little differences in the vauxhall engines (more so the 2.0 )
astra vxr
Re: Turbo Control
Post by astra vxr » Tue Apr 21, 2015 12:16 am
He he :)
if its a z20let sensor it should be a hall sensor (80% sure ) and so is the cam sensor(100%sure ) as its the z20let z20 leh and the z20ler engines that use this sensor and nothing else if it was the vr then it could be used on the 8v and the 2.0 xe or let engines
peter1002
Re: Turbo Control
Post by peter1002 » Tue Apr 21, 2015 4:44 pm
hey
my scope does not know not how I set it
the motor has a hall sensor
will try the ignition map
thank you
Peter
