Hi, quick beginner quesitons: how do I raise a fuel cut rev limit?
Just add fuel over the rev limit with ecumaster?
Thx!
fuel cut rev limit raise
Re: fuel cut rev limit raise
Hi!
It is only possible with Fuel Implant software, where DET3 controls injectors in Speed Density or Alpha N strategy.
would you elaborate more on how the Fuel implant software works? what type of engines does it work with and how the rev limiter will be increased?Jadzwin wrote:Hi!
DET3 in Fuel Implant mode works like fuel stand alone and control injectors. 99% of ECUs make rev limiter by cutting fuel.
Due to the fact that injectors are controlled by DET3 you can set up rev limiter as you wish.
