misfires
alper
misfires
Post by alper » Thu May 14, 2015 7:25 am
hi
I have severe misfires between 6000-8000 rpm.
the gear is Neutral. I tried it on the street - same.
I changed the coils, spark plugs, injectors.
it was running full sequential. I changed it to wasted spark and semi sequential.
result is : same.
m2.emulog
(25.84KiB)Downloaded 87 times
m2.emu
(87.21KiB)Downloaded 106 times
Emu Distributor / Tuner
knastbigger
Re: misfires
Post by knastbigger » Thu May 14, 2015 8:20 am
Hi
Have you tried more fuel and less ignition. I runs a bit lean
What engine is it ?
Br Lasse
alper
Re: misfires
Post by alper » Thu May 14, 2015 8:42 am
I tried every kind of fuel from 11:1 AFR to 15:1 afr
or
more and less ignition too.
doesnt matter.
alper
Re: misfires
and by the way : the car is not moving. it's in NEUTRAL gear.
astra vxr
Re: misfires
Post by astra vxr » Thu May 14, 2015 1:36 pm
whats the crank sensor on it ?
alper
Re: misfires
Post by alper » Thu May 14, 2015 1:58 pm
bosch VR sensor
astra vxr
Re: misfires
Post by astra vxr » Thu May 14, 2015 4:40 pm
is it new sensor ??
we had same problem with a vr sensor worked fine but high rpm it would miss fire so put a new one in it and it would be fine but vr sensors are not very good at high rpm i believe anything over 7500 they play up according to Bosch data
alper
Re: misfires
Post by alper » Fri May 15, 2015 1:27 am
I'm changing the vr sensor tomorrow.
ATS_Scott
Re: misfires
Post by ATS_Scott » Fri May 15, 2015 10:57 pm
I don't see any trigger errors, but I normally don't see them recorded in log unless the advanced filter is turned on. also pull a scope when the misfire is occuring. enable it in Primary trigger, and hold down the blue arrow button to record. scope window is in log menu tree. There are several good filters in the EMU for dealing with weak/noisy VR sensors.
Why is Warm Up enrichment below 100%? you have set to 80 at the current coolant temp you are running.
What Firmware version are you using?
alper
Re: misfires
Post by alper » Sat May 16, 2015 7:21 am
The problem is solved. Bad vr sensor. Fw is 1.19 exp
astra vxr
Re: misfires
Post by astra vxr » Sat May 16, 2015 11:53 pm
glad it sorted it out :)
is doesnt always show up thats its a bad sensor on the logs but 80% of the time at high rpm its usally the sensor at fault
