VSS Audi
Doofy
VSS Audi
Post by Doofy » Thu Jun 04, 2015 8:34 am
Hi!
I can not adjust the speed sensor audi 012409191D
How to configure the sensors setup?
Thank you
Re: VSS Audi
Post by Jadzwin » Thu Jun 04, 2015 1:47 pm
Hi!
Do you have already frequency readings in EMU ?
Doofy
Re: VSS Audi
Post by Doofy » Fri Jun 05, 2015 9:15 am
Jadzwin wrote:Hi!
not
Doofy
Re: VSS Audi
Post by Doofy » Sun Jun 21, 2015 11:16 am
I can not adjust the speed sensor.
Gearbox 01e audi
Help
Re: VSS Audi
Post by Karel » Sun Jun 21, 2015 4:46 pm
Its very, very, very simple !
It works like a swith 8times per revolution.
use VSS setting:
Gear detection type : Calculated
Speedsource : Sensor
Sensor type : Hall/ Optical
Trigger: Falling
Freq. Divider : Divide by 8
Enable pullup: yes
one pin of the sensor goes on sensor ground from EMU, and second goes into the VSS pin of EMU.
After this you need to look into the log and put in the gear ratios.
Doofy
Re: VSS Audi
Post by Doofy » Mon Jun 22, 2015 10:52 am
Thanks! Thanks! Thanks!
