M50B25 Turbo basemap?
KevinC
Post by KevinC » Thu Jun 04, 2015 11:18 am
Hey Guys,
We are busy wiring up and finishing everything around the engine.
It concerns an M50B25 Turbo. Wiseco low compression pistons, ARP head, main and rodbolts, new bearings, Athena headgasket, Siemens 870cc injectors.
Is there a basemap for this type of engine or will it run without good map on the EMU Standalone ECU?
Thanks!
Kevin
killerbee
Re: M50B25 Turbo basemap?
Post by killerbee » Thu Jun 04, 2015 1:28 pm
It is too hard to send base map because nobody from here knows how the emu is wired to engine - outputs inputs sensors and etc ...
Post by Jadzwin » Thu Jun 04, 2015 1:49 pm
Hi Kevin!
You need to confiugure and make tables for your engine setup.
We can help you for sure to get engine start and running.
Post by RHD » Thu Jun 04, 2015 2:10 pm
there is one here that might be similar, its m52
http://www.forum.ecumaster.com/viewtopic.php?f=19&t=492
derOJ
Post by derOJ » Thu Jun 04, 2015 11:35 pm
I wired up all the sensors, plugs and injectors.
then after three or four times of cranking, while adjusting the primary and cam trigger edges, the engine started and runs.
I used the very stock VE and IGN maps, with every cell the same value. VE was all 40, and IGN all 10.
So if your engine doesn't start, there has to be something wrong with your basic settings
derOJ
Post by derOJ » Thu Jun 04, 2015 11:40 pm
killerbee
Post by killerbee » Fri Jun 05, 2015 11:05 am
I have one m50b29 hx35 turbo with same injectors , here is one screenshot of settings that I started it with
killerbee
Post by killerbee » Fri Jun 05, 2015 11:11 am
This is wired as user manual - injector 1 on injector 1 and ignition 1 on ignition output 1 ......... the link you provide there are errors ignition 6 is written g14 but it is injector 5 in manual - please pay your attention when wiring anything on cars
KevinC
Post by KevinC » Fri Jun 05, 2015 3:34 pm
Hi Guys,
Thanks for the replies so far.
My loom is made by Greg from RRR Engineering in the UK, he is also a EMU ECUMaster dealer.
He is kind enough to help my getting setup through teamviewer when we're so far (y)
gregpe
Post by gregpe » Sat Jun 06, 2015 9:55 am
Attached spec of Kevin wiring :)
BMW M50 turbo wiring .pdf
(729.47KiB)Downloaded 133 times
