Readings do not match
pepifebles
Post by pepifebles » Tue Jun 16, 2015 11:02 pm
Hi guys,
My aem wideband gauge shows mixture about 11.8/12 and Emulog can see about 13 or more (fuel target its set to 11). When my boost gauge shows 1,1bar, emulog shows nearly 1,3bar (target its set to 1,2). Why can this happen?. Tps do not calibrate correctly, when I push full pedal, only get 98%. I will modify the voltage to fit 100%, but this may be the reason to wrong/different readings?
Regards
The fun starts now
Re: Readings do not match
Post by PSI-Motor » Tue Jun 16, 2015 11:20 pm
You havn't synked the wideband to the ecu.
Always look at map pressure and not your guage.
Go in under sensor setup and calibrate your tps
pepifebles
Post by pepifebles » Tue Jun 16, 2015 11:33 pm
PSI-Motor wrote:You havn't synked the wideband to the ecu.
How synk my wideband with ecu?
My boost gauge its ok. Gauge and Blitz boost controller shows the same value.
The fun starts now
Post by PSI-Motor » Tue Jun 16, 2015 11:44 pm
Go in under sensor setup and oxygen sensor, it will say 0v = 7.38 afr and 5v = 22.38 afr
Try changing it to 0v = 10 afr and 5v = 20 afr
Go in under mapsensor and calibrate it manually untill your guage in the ecu shows 101kpa with the engine not running.
pepifebles
Post by pepifebles » Wed Jun 17, 2015 12:03 am
Go in under mapsensor and calibrate it manually untill your guage in the ecu shows 101kpa with the engine not running.[/quote]
0v=10 afr and 5v=20 afr always have been my set. ;)
The fun starts now
Post by PSI-Motor » Wed Jun 17, 2015 12:10 am
pepifebles wrote:Go in under sensor setup and oxygen sensor, it will say 0v = 7.38 afr and 5v = 22.38 afr
0v=10 afr and 5v=20 afr always have been my set. ;)[/quote]
The guage should be grounded at the same place as the ecu.
Then try 10 and 19 and then 9 and 20 and so on
Mobilelpg
Post by Mobilelpg » Thu Jun 18, 2015 3:26 pm
I finally got my later type (more linear) AEM to read perfect in the ECU with a setting of
0v = 10 AFR
5v = 19 AFR
Edward.
pepifebles
Post by pepifebles » Thu Jun 18, 2015 4:41 pm
Mine to iddle runs fine, the different its about 0.01/0.02 but At high rpm the differential are bigger.
The fun starts now
Mobilelpg
Post by Mobilelpg » Thu Jun 18, 2015 6:01 pm
Mine was the same using the AEM recommended 0v=10 and 5v=20.
At idle and cruise it was almost bang on but when I put my foot down it went off scale.
I calibrated it bringing the revs up slightly to avoid a stall from rich mixture, then richened the mixture so the gauge read 11.5, then adjusted the settings under oxygen sensor so that the log read 11.5.
I then leaned off to around 16.5 and did the same.
My log now reads accurately.
Edward.
pepifebles
Post by pepifebles » Thu Jun 18, 2015 11:32 pm
Thanks for your help but, sorry, have no idea how do it. My English is not very good and I can not understand you correctly. How to calibrate the AEM ?
Actually my tuner has good controlled emu software to boost and ignition, but mixture is very poor and we dont know if this can be the reason or there is any map incorrectly set.
The fun starts now
Mobilelpg
Post by Mobilelpg » Fri Jun 19, 2015 3:01 pm
No Problem.
Go into Configuration > Sensors setup > Oxygen sensor.
With the new oxygen sensor window open, near the bottom it says "AFR at 0v" try entering 10.
Then below that is says "AFR at 5v" enter 19.
Those figures worked for me but you may have to try slight variations.
Hope this helps,
Edward.
Post by PSI-Motor » Fri Jun 19, 2015 3:14 pm
AEM has this problem with all ecu brands not just emu.
pepifebles
Post by pepifebles » Fri Jun 19, 2015 3:15 pm
Mobilelpg wrote:No Problem.
Hope this helps,
Edward.
Thanks.
The fun starts now
pepifebles
Post by pepifebles » Tue Jun 23, 2015 11:17 pm
Hi guys,
Its correct this IAT Calibration to my 3sgte?
I have too much IAT boost correction (90%) and log show 65º IAT a few kilometers normal drive, without full boost. With other map havent this problem.
EV_3.emulog
Log
(174.96KiB)Downloaded 80 times
The fun starts now
