Any example to good flat shift set? Something like this, amazing
I dont know if this is flat shift or ALS.
https://www.youtube.com/watch?v=tpb3x0uZxuI
Flat shift
pepifebles
The fun starts now
Re: Flat shift
This is 2step launch control + als .... everything included in EMUpepifebles wrote:Any example to good flat shift set? Something like this, amazing
pepifebles
Re: Flat shift
How to configure emu launch to get explosions? its dangerous to my Engine??
The fun starts now
Re: Flat shift
It will shorten the turbo life time, and add extra stress on exhaust valves, and over heat the exhust manifold, the wilder you go the more damage you make, but we do it all the time specially ALS, that holds like 0.5Bar on throttle release.
Re: Flat shift
I believe you have a 3sgte, be very careful with launch, ALS etc.. If on stock pistons, you might be upgrading sooner than planned. If you already have forged pistons then Have fun!
Re: Flat shift
I recently killed my std ceramic catalytic converter by adjusting the LC for "good bangs" out of the exhaust... When just using enough hysteresis and much ign retard (keep an eye on your exhaust gas temps!) even a standard cat will survive it, as optimally there will no explosions happen in the exhaust.
As you can hear, the turbo just spools
https://www.youtube.com/watch?v=1K_Vp0BeImM
Re: Flat shift
i used to get about that boost with just a extra switchable rev limiter but with 4wd you need a rev set at around 5.5k for any decent launches . with the emu and the fact i have no cat i will have lots of bangs
pepifebles
Re: Flat shift
My engine is forged (pistons and rods) and havent Cat.
Today activated LC and its pornographic jajaja explosions like I want it.
The fun starts now
