vr6 turbo help please
J4ygt
Post by J4ygt » Tue Jun 23, 2015 8:44 pm
Hi I'm Jay I am new to the forum I have recently bought a EMU standalone ready to be fitted into my golf vr6 turbo would anybody have the pin out diagrams for the engine loom also a start up map many thanks in advance Jay!
Spec Sheet:
Car Model and Year: vw golf vr6 1997
Engine: vr6 AAA coil pack
Harness Model/Year:
Engine Mods: re bore to 82mm pistons 2900cc low cut thermostat all arp bolts all new bearing and oilpump.
Pistons/Rods: Wosser low comp pistons and eagle h-beam rods Compression: 8.5.1
Head Work: slight porting with oversize supertech valves inlet 39mm exhausts 42mm
Camshaft Schimmel Performance sp263 cams
Intake Manifold: custom short run intake
Throttle Body: standard
Exhaust Manifold: cast log manifold
Turbo: holset hx35 14cm2 7blade
Intercooler: front mount 600mm x 165mm
Fuel Injectors: siemans deka 630cc
Fuel Pressure: 3bar
Fuel Pump: bosche 044
Fuel Type: 99 ron pump
J4ygt
Re: vr6 turbo help please
Post by J4ygt » Tue Jan 05, 2016 12:33 am
J4ygt wrote:Hi I'm Jay I am new to the forum I have recently bought a EMU standalone ready to be fitted into my golf vr6 turbo would anybody have the pin out diagrams for the engine loom also a start up map many thanks in advance Jay!
Spec Sheet:
Harness Model/Year:
Fuel Pressure: 3bar
anybody can help me??
Post by RHD » Tue Jan 05, 2016 12:47 pm
you may need to find a wiring diagram for your car that should have all the ecu pinouts you can follow
