I hope you can help my to get my bluetooth module running. I can't find any instructions on this.
What I want to know is the code for pairing with the android device.
I also wonder if there is any requirements on the device, android version etc. What is the best device to get that is known working good?
I want a smaller tablet for fixed mounting in the car.
Best Regards
Gustav
Bluetooth module and android device
- Kisielisodd
- ECUMASTER TEAM
Re: Bluetooth module and android device
Code is 1234 for paring
Both vems display, and ecumaster unfinished app works 7" and 10" table. I tried Vems dislay and ECUMaster app on phone with 3.5" screen and it worked ok.
Hi
I have problem with my Bluetooth module , I've tried 2 cars with EMU and 3 android devices - 2 phones and 1 tablet . Every time I pair new android device it connect with Vems Display for 2 seconds - in upper part of screen it shows 1hrz then 0 hrz and disconnect - then this android device can not be connected again - I must unpair then pair and again it has connection only for 2 seconds . Can someone help me with this problem .
Firmware used - first car 0.9xx , second 1.0xx , tried 3 or 4 vems display version - same
We had only such problems on Lenovo tablets. On Samsung / Sony Vems display works great.
Here is our guide how to connect to Vems Display. Please check if your way was the same.
- BT module to vemsdisplay.pdf
- (718.81KiB)Downloaded 180 times
Today will get Samsung tablet to test
Now I have tried with two different Samsung devices and I get exactly the same problem as the previous user. Vems shows connected for 0,5 sec the it stops.
The LED on the bluetooth adapter never stops flashing. I doesn't work with your own app either. It just hangs.
I use the latest firmware and the latest test version of the software. Please help!
Thanks!
//Gustav
Thanks!
//Gustav
So please contact us at info(at)ecumaster.com, we will replace your BT module.
Asus tablet - do not work
Huawei phone P1 - do not work
THL w200s octa core - do not work
Samsung galaxy s3 mini - work
- ktsirigotakis
Hi to all i am interesting to bay a 2din chines radio that have android inside will they work with emu Bluetooth?
for example:
http://www.aliexpress.com/item/2DIN-Cap ... 90384.html
for example:
