5 Position Boost Switch works but can I do Boost by speed 2
So the Mux switch method for a boost controller switch works great however for traction control I want to use boost by speed using an abs signal from one of my front wheels for traction control. Is there such a way while still using the mux switch?
Re: 5 Position Boost Switch works but can I do Boost by spee
You can scale the current boost tables using VSS (VSS correction table).
