Toyota Aristo JZS161 2JZGTE VVTI
Deni Dermawan
Post by Deni Dermawan » Wed Aug 19, 2015 3:24 pm
Dear All,
I am installing ECUMASTER EMU STANDALONE on Toyota Aristo JZS161 2JZGTE VVTI.
I have been working on this project for 3 months but still unsuccessful.
Right now I am having problem connecting ECUMASTER EMU to laptops.
There is no connection either on Windows 8 or Windows 10 (both 64 bit).
All laptops are fine as well as all USB ports.
What can be problem?
I believe ECUMASTER EMU is powered when key is switched on since there is heat on its casing.
Until now no luck to bring engine alive.
gregpe
Re: Toyota Aristo JZS161 2JZGTE VVTI
Post by gregpe » Wed Aug 19, 2015 4:22 pm
hi
install newest driver..
http://www.ftdichip.com/FTDrivers.htm
and check if is connecting..
Deni Dermawan
Post by Deni Dermawan » Wed Aug 19, 2015 4:33 pm
Dear All,
"Please check if there is no short circuit on EMU +5V output"
ECUMASTER technical support said above statement but no further explanation.
From ECUMASTER EMU pin B17, B18, B23, B24, G17,G18, G24, where should be wired?
I enclose Aristo pin out for reference.
Cheers
Pin Out.pdf
(198.95KiB)Downloaded 95 times
Plug.pdf
(168.83KiB)Downloaded 71 times
Deni Dermawan
Post by Deni Dermawan » Wed Aug 19, 2015 4:35 pm
Thanks to "gregpe".
I will try tomorrow.
The car at workshop........It is 10.34 PM now.
Deni Dermawan
Post by Deni Dermawan » Thu Aug 20, 2015 2:29 pm
Dear gregpe,
I installed "CDM v2.12.06" on Windows 10 64 bit.
Device detected/found.
But it shows "This device is not able to work with US Windows version!"
Try to install "CDM v2.12.00".
Display "This device is not able to work with US Windows version!"
I switch to old laptop, Windows 7 32 bit Pro.
First I do not install "CDM v2.12.06".
Device (ECUMASTER) undetcted.
Then install "CDM v2.12.06".
Device detected/found but it shows "This device is not able to work with US Windows version!"
Same message appears by installing "CDM v2.12.00".
How to solve this problem?
I enclose screen shot from both laptops.
Cheers
Deni Dermawan
Post by Deni Dermawan » Thu Aug 20, 2015 3:48 pm
Images
LukaszR
Post by LukaszR » Thu Aug 20, 2015 8:32 pm
You need to update to latest firmware 1.138. Search forum for test versions link. Or maybe someone will post it up here
vortex
Post by vortex » Thu Aug 20, 2015 9:43 pm
Change the language of the control panel in you windows. I have had the same problem. English windows but acted emu in Sweden . had to do a language update to Swedish.
Deni Dermawan
Post by Deni Dermawan » Fri Aug 21, 2015 1:34 am
Thanks to LukaszR and vortex.
Deni Dermawan
Post by Deni Dermawan » Fri Aug 21, 2015 2:32 pm
Dear Vortex,
Today We change Windows language to Polish, Spanish, German, not working.
We change Windows region, not working.
We update "machineInfo.dat" given by ECUMASTER
Message still appear "This device is not able to work with US Windows version!".
We try a laptop from Singapore market (Windows 7 64 bit).
Not working.
Cheers
Deni Dermawan
Post by Deni Dermawan » Fri Aug 21, 2015 2:38 pm
I install "EMUSetup_1_1_RC1" from USA website.
The same message "This device is not able to work with US Windows version!".
Then update "machineInfo.dat", same message.
I installed "EMUSetup_1_138" given by ECUMASTER.
Anybody???????
gregpe
Post by gregpe » Fri Aug 21, 2015 3:08 pm
is your laptop with US version of Windows?
Deni Dermawan
Post by Deni Dermawan » Fri Aug 21, 2015 3:12 pm
"is your laptop with US version of Windows?"
How to check if it is US version or Europe version or Asia version?
All 3 laptops were bought in Indonesia, one laptop bought in Singapore.
