Opel 3.2 v6 need startup map
kadettgsi16v
Hello here on the forum...
Can anyone help me with a startup map for a opel
3.2 v6 engine stock cranksensor and wheel 60-2 with no ignition module and standard coilpack... at the moment running 2.5 intake no idle motor.. high compression pistons octane 99 fuel... if you just can help me with all the trigger info on the engine i would be very happy... kind regards René from denmark xecuter@live.dk
peder olin
Re: Opel 3.2 v6 need startup map
Someone please help!
Desperatly need help
look like nobody done it .. or nobody want to share bur in EMU crating start map is very easy..peder olin wrote:Someone please help!
1 start from reading manual and help files in software.
2 connect all wires.
3 check trigger setings on scope.
4 next ignition timing lamp to find correct angle.
5 use correct setting for injector size and engine .
6 put in VE map about 40 on area of idle.
7 in engine start cranking fuelling something between 3 and 5 ms and you should get it running.
THE MOST important is first point READ MANUAL
peder olin
I already got the basic setting from my megasquirt.. i just got problems with both the tps,clt og iat sensors..
The tps is not showing any changes when i twist the throttle from zero to full..
look like wiring problem double check wiring as you have a problems with almost all sensors check sensors ground.
kadettgsi16v
A base map for a c25xe or x30xe is also fine
your tps is problably connected wrong.
Do you have IAT, CLT GM numbers ?
peder olin
We finally got the wiring right,the only thing left now is which injector to spray when.. i am running a wasted spark and the firingorder is 1,2,3,4,5,6.. my question is on what ign. Event the injector is ment to spray.. sorry for my stupid questions
kadettgsi16v
And anybody know the right trigger angle and first trigger tooth... engine almost running now... please help c25xe x25xe x30xe y32se
Hi!
Please try to use those settings:
ALWAYS CHECK THE TIMING WITH THE TIMING LAMP
kadettgsi16v
Thanks we will try... we dont use 2 trigger only crank trigger
So do not forget to pair coil outputs (for wasted spark)
peder olin
I am using a stock coilpack from a normal opel v6 with 3 input and 6 sparkplugwires connectors.. do i still have 2 pair the outputs?
The car is cranking and moving to afterstart and then it dies again,we tried changing the fuel on every possible way but nothing give us a big change..
kadettgsi16v
Car is running now... thought the fuel map was in milli seconds but its micro seconds so needed way more fuel...
