EMU new tool in software 1.166
Post by Jadzwin » Thu May 12, 2016 10:33 pm
Hi All!
There is new version 1.166 and there are some new features that could help a lot:
OUTPUTS TEST
Output - output to be tested
Num cycles - number on/off cylces to perform
Cycle on time - time during output is active
Cycle off time - time during output is inactive
For ignition outputs the on time is limited to 20ms (even set longer).
Outputs could be assigned to strategies durin test (the test procedure disable the strategy for tested output)
LOG CHANNELS PRESETS
Log channels presets could be defined and edited by user. Presets could be also grouped (Use / for the group name eg. My Presetes\Fuel )
CONNECTION MESSAGE
When connected device calibration differs from current windows client calibration user is able to select what calibration should be used.
nickbmw
Re: EMU new tool in software 1.166
Post by nickbmw » Fri May 13, 2016 12:42 pm
Nice, very usefull changes.
R-tune
Post by R-tune » Fri May 13, 2016 12:56 pm
I also like the changes, especially the check for inconsistent data at connection!
When will there be a next stable release for EMU firmware?
Post by Jadzwin » Fri May 13, 2016 1:51 pm
In next few weeks. Actually we try to freeze changes and focus on tests.
However this release seems to be very stable.
